![]() | Home > Technical (L322) > HELP - misfiring and cutting out....experts baffled |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 ![]() ![]() ![]() |
This might be a bit late but where did you buy the petrol
ALEX1 Member Since: 11 Apr 2014 Location: liverpool Posts: 5 ![]() |
No its not the petrol as i have filled up several times by now from different places. I am guessing that it could be the fuel pump but dont know how to narrow it down |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
I take it they plugged it in? There is nothing that can't be fixed with a hammer😜😜
The car has left the service garage 3 times now running fine - but after a few days the problem appears as if its something that just builds up with use.....but i cant figure out what |
I think the AA man may have been right... It takes 75 miles for the engine to fully learn new adaptions and if the garage reset the adaptions then it would behave for a few days...
The camshaft sensor has been replaced but the problem pessists. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
If the fault persists then maybe a wiring issue up to the sensor.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
I would check instrument cluster, sounds daft but that was my issue, needed to be replaced and apparently only by a main dealer |
Is it definetly not a fuel pump issue? Why does it run ok when the mechanics have had a fiddle with it and then start playing up a few days later? |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi ALEX1,
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 ![]() ![]() |
My local garage could not diagnose it so ended up having to take it to the main dealer. It was the fuel injectors - 4 out of the 8 had to be replaced. Dealer quoted £2k for the job! Yikes! |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
I find setting the cruise to approx 59mph has them reset in about 20 motorway minutes ![]() 45 minutes idling will clear any that don't reset after that . Having injectors tested and ultrasonicLly cleaned has worked for me in the past as an alternative to replacement |
