![]() | Home > Maintenance & Mods (L322) > Removal and Refitting of Front Air Susp. - Photo Tutorial |
| kerniki Member Since: 13 Feb 2012 Location: south Posts: 1
hi from a newbie |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Yep, it's behind the rear RH wheel arch liner.
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
Did you manage to do the near side without removing the wheel arch liner? 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Resurrecting the thread a bit but looks as if I am going to have to do the fronts. Excellent write up Joe. |
A little tip. If your replacing an already punctured bag? Cut the bag with a stanley knife and this will let the air out & negate the need to remove the wheel arch liner and let the air out of the line |
Thanks Craig. |
@ Weegie
Thanks J90 |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
You can't really get it wrong, it only fits one way round....
Thank you. |
Perhaps need to qualify the alignment point:
| viper Member Since: 11 Apr 2015 Location: manchester Posts: 271
could one do a shock absorber change and retain the existing airbags if they are in good condition? do they seperate |
Absolutely Joe & a fair point BUT... If your lower hub to shocker bolts undo, the strut can easily be changed in around 45mins without the need to remove the liner IF..... The job needs doing as an emergency to get you back mobile again sir, that was my tip for saving time If its a planned job, then thoroughly checking all the other components in the area is of course a good practice and corners should not be cut |
Don't think that scenario would arise, when either needs changing it wouldn't be worth doing just one, to answer your question yes they do split, Arnott sell just the bag but I've never seen just the shock for sale... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
| All times are GMT |
