Home > Maintenance & Mods (L322) > Removal and Refitting of Front Air Susp. - Photo Tutorial
Page 2 of 3 <123>
kerniki
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
hi from a newbie Very Happy
anyone know where the 'rear' cross link valve is?
Post #107061 13th Feb 2012 10:28am
Yep, it's behind the rear RH wheel arch liner.
I guess this will be one of my next jobs when the rear air bags give way..... .
Post #107195 13th Feb 2012 10:26pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Very useful thread
Once again FFRR.com has saved me some dosh.
I can barely change a lightbulb but today with the help of this thread I plucked up the courage to have a go at changing the front passengers side air strut. It had collapsed, hissing noise so I assumed it was punctured, the front of the vehicle was on it's bump stops too.
In total it is just seven nuts, twelve if you include the five wheel nuts, it was all done in about two hours even including liberal quantities of tea whilst waiting for the easing oil to free up the stubborn bolts.
Not too pricey either, £227 + vat for the Dunlop strut with 24 months warranty, very pleased chappy here. I'll do the other side next week.
God I love my rangie lol. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #115741 31st Mar 2012 2:07pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Did you manage to do the near side without removing the wheel arch liner? 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #254407 14th Apr 2014 3:29pm
Weegie
Resurrecting the thread a bit but looks as if I am going to have to do the fronts. Excellent write up Joe. Thumbs Up
I have three questions if anyone can assist.
Does the replacement unit come with the paper gasket mentioned or has it to be sourced separately?
Is it worth (necessary?) to get new bolts?
Reference is made to marking the alignment of the inner bolt on the top of the turret. I am not quite clear as to what is intended. Do the three bolts on the top not fall into place without adjustment or is there some "wriggling" to be done?
Thanks in advance. John
GAP iiD BT-Sold
Post #357575 18th Nov 2015 1:06pm
A little tip. If your replacing an already punctured bag? Cut the bag with a stanley knife and this will let the air out & negate the need to remove the wheel arch liner and let the air out of the line Thumbs Up
Makes the top airline slightly more tricky but with two pairs of hands, (one to hold the strut and one to undo it) saves quite some time Thumbs Up
GREAT write up Joe Bow down Bow down Bow down
Post #357578 18th Nov 2015 1:32pm
Weegie
Thanks Craig. Thumbs Up
Was going to use GapiiD to deflate but a quick stab to a deflated bag would perhaps be more in keeping with my atavistic urges. Embarassed Very Happy Very Happy John
GAP iiD BT-Sold
Post #357580 18th Nov 2015 1:44pm
@ Weegie
I didn't new paper gaskets, reused existing
Reused existing bolts as all OK, choice is yours
Reference mark for alignment.....
@ Craig
Nice tip, although depending on age of car one might wish to check out the condition of the brake pipes, especially on LHS! Even if this might make one even poorer! .
Post #357609 18th Nov 2015 6:20pm
Weegie
Thanks J90 Thumbs Up
Still a bit unclear about the reference marks. Does it mean alignment with the bottom bracket at the hub to ensure that it is on the right way round?
Sorry if I'm being thick. Maybe become clear when I get to it? John
GAP iiD BT-Sold
Post #357611 18th Nov 2015 6:32pm
You can't really get it wrong, it only fits one way round....
Both my paper gaskets were crumbs.... I left them out, its been fine... Thumbs Up
Bottom strut nuts and bolts suffer from the salt... have a check before you do the job or just get some new ones, they aren't much money.... Thumbs Up Pete
-Click here for Thread-
Post #357613 18th Nov 2015 6:40pm
Weegie
Thank you. Thumbs Up John
GAP iiD BT-Sold
Post #357614 18th Nov 2015 6:43pm
Perhaps need to qualify the alignment point:
a) could be for correctly refitting the existing strut?
or
b) perhaps they have a special alignment tool for the strut in the factory, and this helps to replicate that?
There is a bit of play in the three holes for the studs on the strut, so just helps to get the strut centred properly.... .
Post #357654 18th Nov 2015 11:31pm
viper
could one do a shock absorber change and retain the existing airbags if they are in good condition? do they seperate
Post #357668 19th Nov 2015 12:11am
Joe90 wrote:
@ Weegie
@ Craig
Absolutely Joe & a fair point BUT... If your lower hub to shocker bolts undo, the strut can easily be changed in around 45mins without the need to remove the liner IF..... The job needs doing as an emergency to get you back mobile again sir, that was my tip for saving time Thumbs Up Thumbs Up Thumbs Up
If its a planned job, then thoroughly checking all the other components in the area is of course a good practice and corners should not be cut Thumbs Up
Post #357671 19th Nov 2015 12:40am
Don't think that scenario would arise, when either needs changing it wouldn't be worth doing just one, to answer your question yes they do split, Arnott sell just the bag but I've never seen just the shock for sale... Pete
Post #357673 19th Nov 2015 1:20am
Page 2 of 3 <123>
