![]() | Home > Technical (L322) > L322 Refusing to start |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
Sounds like the same issue I had. No warning, drove fine, parked up at work, then came out and just turned over.
| Flunter Member Since: 27 Apr 2014 Location: East Yorkshire Posts: 26
Thanks for that. It does sound very similar.
Now I'm totally puzzled.
Strange. I didn't have that issue.
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
That sounds more like a case of dodgy immobiliser not turning off properly. re-lock and then unlock the car will cycle the immobiliser. Just a thought. |
I had been advised that it was probably the immobiliser so I'd done all the locking/unlocking stuff but it made no difference.
| adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204
Unfortunately it will your remote fuel pump is on the way out |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Yep, had exactly the same issue, had it trailered to the mechanics and it started and drive normally when it got there. They did a voltage check on the pump and found that it was not at optimum leading to it being temperamental, so they replaced it and it was fine afterwards. Luckily not the in tank pump.
Thanks again chaps.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
The fuel pump is a very common issue on the TD6s and if you trawl the forum, you will see a lot of issues like you are having turn out to be the pump on its way out. If you are not certain the pump has been changed at any time, it is a pretty safe bet to have it replaced. Not sure if it is very expensive but I don't believe it is.
| L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51
Hi, Had exactly the same issu on my 2004 TD6. Was the fuel pump, it did 3 times, the 4th never started again. At least the car is sending you a warning message! Total cost for me was 325€ here in Germany |
Evening peeps,
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Time to find a new 'Master Technician' then |
| clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51
probably one of thos master techs that can only work with a computer pluged in |
| All times are GMT |
