![]() | Home > Technical (L322) > 5.0 S/C common issues? |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I haven't found any in my 1 week 4000 km run |
| somchie Member Since: 31 Mar 2014 Location: G�teborg Posts: 42
Actually, I'm starting to believe that the fuel consumption is more of a feature |
I did mostly highway driving and the computer showed around 15 L / 100 km |
I believe the SC engines are virtually bulletproof (if maintained and used properly) and that is one of the reasons I decided on getting an SC iso a TDV8. Also the gearbox (I had a well documented problem with my 4.2 gearbox) is also the upgraded and uprated version so I expect nothing to go wrong with it (and man does it shift well).
| CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750
I've had a few electronic problems (alarm going off for no reason, see separate post), FBH has never worked properly (see separate older post) and problems with DVD player which is now sorted.
| SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792
I've heard nothing but praise for the 5.0 although I'm thinking of starting some rumours to try and bring the prices down!
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
When you say it uses less fuel, in the same way that Gazza drinks less than George Best did! |
I heard the fuel consumption of the 4.2 is generally higher than the 5.0. For me, I can't make a comparison as my 4.2 was driven in Nigerian traffic compared to the trip with the 5.0 in Europe with mostly highway driving. The 4.2 was thirsty and the few instances I did drive it on "normal" roads it did come down to "normal" figures.
| B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191
I am just starting my 7th month of 5.0 SC ownership and have loved every single day of it. No faults to report apart from the bluetooth phone connection occasionally going AWOL. A re pairing sorts it for about 3-4 weeks at a time. Parking the car for short periods (minutes))seems to exacerbate the problem!
| XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995
i drive my car in town for the most of the time and i live in Stuttgart so i have to chase Porsches all the time |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
^ do you catch them though.....? |
they are kinda surprised when i pull off a red light |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
^ I used to fly off the light in the Land cruiser years ago but used low box ( I had done the mod so the centre diff wouldn't lock when in low range), only thing you ran out of steam at 30mph! |
| All times are GMT |
