![]() | Home > Technical (L322) > 5.0 S/C common issues? |
I haven't found any in my 1 week 4000 km run |
somchie Member Since: 31 Mar 2014 Location: G�teborg Posts: 42 ![]() ![]() |
Actually, I'm starting to believe that the fuel consumption is more of a feature |
I did mostly highway driving and the computer showed around 15 L / 100 km |
I believe the SC engines are virtually bulletproof (if maintained and used properly) and that is one of the reasons I decided on getting an SC iso a TDV8. Also the gearbox (I had a well documented problem with my 4.2 gearbox) is also the upgraded and uprated version so I expect nothing to go wrong with it (and man does it shift well).
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
I've had a few electronic problems (alarm going off for no reason, see separate post), FBH has never worked properly (see separate older post) and problems with DVD player which is now sorted.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I've heard nothing but praise for the 5.0 although I'm thinking of starting some rumours to try and bring the prices down!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6791 ![]() ![]() ![]() |
When you say it uses less fuel, in the same way that Gazza drinks less than George Best did! |
I heard the fuel consumption of the 4.2 is generally higher than the 5.0. For me, I can't make a comparison as my 4.2 was driven in Nigerian traffic compared to the trip with the 5.0 in Europe with mostly highway driving. The 4.2 was thirsty and the few instances I did drive it on "normal" roads it did come down to "normal" figures.
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
I am just starting my 7th month of 5.0 SC ownership and have loved every single day of it. No faults to report apart from the bluetooth phone connection occasionally going AWOL. A re pairing sorts it for about 3-4 weeks at a time. Parking the car for short periods (minutes))seems to exacerbate the problem!
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
i drive my car in town for the most of the time and i live in Stuttgart so i have to chase Porsches all the time |
^ do you catch them though.....? |
they are kinda surprised when i pull off a red light |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
^ I used to fly off the light in the Land cruiser years ago but used low box ( I had done the mod so the centre diff wouldn't lock when in low range), only thing you ran out of steam at 30mph! |
