![]() | Home > In Car Electronics (L322) > Removing HK amp |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
..as in - how the heck do you do it??
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
It's not screwed or bolted at the bottom, but I remember it slotting in somewhere.
This is all new to me as all my other cars have just had a head unit! I'm looking at this thing... |
Just had a quick search for your part number and it's the dsp unit.
Sorry, was typing while you posted.
I'll fire rave up and see what it says - still finding my way around that... Tym
Here is a pic from another thread, be aware it details how to remove the BM54 radio unit, which is at the side of the dsp, but it will give you a start and shows the plastic tray I'm on about ;
Wow - Thank you so much for your help. I used that as a starting point and found 86.50.36 which seems to deal with the power amplifier removal which looks to be in a similar location to my dsp. Between these - I should be able to do it now. Thanks.
Rave will call the dsp the amp, so that's exactly what you need to do.
If I got one from a BMW with the same part number, will it need recoding or should it work our of the box? Tym
It should work fine. I've swapped radio modules without an issue, can't see the dsp being any different.
Found this thread...
Ah, not quite as straightforward to remove as the radio module then !
Ah... must admit I didn't *check* as such when I was checking the connections, but I'm sure that i'd gone straight into the boot from the car being parked a while. I *should* be ok! |
What an adventure today has been! Got the DSP out - piece of cake if you follow the instructions in rave...
