Home > In Car Electronics (L322) > Removing HK amp |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 299 |
..as in - how the heck do you do it??
29th Apr 2014 7:11pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
It's not screwed or bolted at the bottom, but I remember it slotting in somewhere.
29th Apr 2014 7:26pm |
This is all new to me as all my other cars have just had a head unit! I'm looking at this thing...
29th Apr 2014 7:32pm |
Just had a quick search for your part number and it's the dsp unit.
29th Apr 2014 7:33pm |
Sorry, was typing while you posted.
29th Apr 2014 7:37pm |
I'll fire rave up and see what it says - still finding my way around that... Tym
29th Apr 2014 7:39pm |
Here is a pic from another thread, be aware it details how to remove the BM54 radio unit, which is at the side of the dsp, but it will give you a start and shows the plastic tray I'm on about ;
29th Apr 2014 7:43pm |
Wow - Thank you so much for your help. I used that as a starting point and found 86.50.36 which seems to deal with the power amplifier removal which looks to be in a similar location to my dsp. Between these - I should be able to do it now. Thanks.
29th Apr 2014 7:50pm |
Rave will call the dsp the amp, so that's exactly what you need to do.
29th Apr 2014 7:59pm |
If I got one from a BMW with the same part number, will it need recoding or should it work our of the box? Tym
29th Apr 2014 8:47pm |
It should work fine. I've swapped radio modules without an issue, can't see the dsp being any different.
29th Apr 2014 8:53pm |
Found this thread...
29th Apr 2014 9:06pm |
Ah, not quite as straightforward to remove as the radio module then !
29th Apr 2014 9:39pm |
Ah... must admit I didn't *check* as such when I was checking the connections, but I'm sure that i'd gone straight into the boot from the car being parked a while. I *should* be ok!
1st May 2014 8:55am |
What an adventure today has been! Got the DSP out - piece of cake if you follow the instructions in rave...
1st May 2014 8:20pm |
