![]() | Home > Maintenance & Mods (L322) > GM 5L40E - Trans Fail Safe Prog. |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Boing Trans Fail Safe Prog
I would thoroughly flush the cooling system and maybe replace cooler & pipes first. Check that the bottom half of the MAIN radiator is not choked with gunk. Then flush box and new oil then hope for the best. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35822 ![]() ![]() |
interesting thread here on another forum that might help ,
^ Interesting but I think its about the ZF 5HP24 not the GM5L40E box. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1030 ![]() ![]() |
I would definitely remove the sump to check for metallic debris (usually caused by the torque converter lock-up clutch having worn through its lining)
Sorry to be harbinger of doom, but sounds just like my tale of woe when my box died on me (ended up with replacement) |
Thanks All
bainbo1 Member Since: 13 May 2014 Location: North Yorks Posts: 2 ![]() ![]() |
Hi Guys
