![]() | Home > Maintenance & Mods (L322) > ROOF PROBLEM! |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
Hello,
There are six treaded holes to screw the roof rack in to , these need treaded bolts put back into them I take it yours are now missing ? you might find an M5 or M6 bolt that fits I'm not sure about the size . If the plastic flaps have been cut off you must buy new trims entirely from your dealer and have them painted and fitted because the plastic flaps cannot be fitted back on after they have been cut off |
Thanks for the replies!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
From memory the 6 threaded holes in the fixing points won't leak even if the grub screws (8mm thread) are missing, the holes are blind ie they don't go right thro the roof. |
Or get a roof rack |
I just was scared when i saw the old tape in the holes!!!
