Home > Maintenance & Mods (L322) > ROOF PROBLEM!
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
ROOF PROBLEM!
Hello,
I think the previous owner of my FF have fitted an roof rack/rail/bar system and have cut the channels covers out of the roof and i have the holes on the roof and the water get inside...
There is any way to fix this and cover the holes?
Many thanks! Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #257717 5th May 2014 9:33am
There are six treaded holes to screw the roof rack in to , these need treaded bolts put back into them I take it yours are now missing ? you might find an M5 or M6 bolt that fits I'm not sure about the size . If the plastic flaps have been cut off you must buy new trims entirely from your dealer and have them painted and fitted because the plastic flaps cannot be fitted back on after they have been cut off Big Cry 2008 MY Supercharged
Post #257720 5th May 2014 9:59am
The channel covers do not seal the roof, water should not get inside even if they are missing, check that the small grub screws arent missing from the fixpoints though these also shouldnt let water in!
Unfortunately the covers are not available separately and if you want to put them back you will need whole new gutter trims, which will need paint. There is nothing that can't be fixed with a hammer😜😜
Post #257725 5th May 2014 10:23am
goncalo
Thanks for the replies!
What caught my attention was some old cranky tape on the rails... i thought the water can get inside and make some damage!
I'm more relaxed now! I gonna check that if the small grub screws aren't missing from the fix points!
Thanks! Ex-FULLFATTY now downgraded
Post #257732 5th May 2014 10:45am
From memory the 6 threaded holes in the fixing points won't leak even if the grub screws (8mm thread) are missing, the holes are blind ie they don't go right thro the roof. Thumbs Up
Post #257746 5th May 2014 1:07pm
Or get a roof rack Thumbs Up .
Post #257761 5th May 2014 4:23pm
goncalo
I just was scared when i saw the old tape in the holes!!!
Now i'm more relaxed about this... but i gonna check the screws! Ex-FULLFATTY now downgraded
Post #257764 5th May 2014 5:58pm
