Home > Technical (L322) > dual-view touch screen
mzplcg
An off the wall question but is it possible to replace the front face of the touch screen? (without replacing the whole unit)
Mine's got the permanent fingerprints and I'd like to be rid of them if possible.
Ta. Dom.
Post #258204 8th May 2014 11:41am
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
I can't find the post but I seem to recall that someone here noted that on the dual-view, the screen had an extra "film" layer over the screen which gave rise to the permanent fingerprints, and this could be removed by using baby wipes or some sort of flash wipe equivalent. This got ride of the extra film and made the screen easier to clean, although not sure if this affected the dual-view function or not.
I also looked into this when I bought my car as I thought the screen had fine scratches and concerned that fingerprints could not be cleaned off. Haven't replaced the screen or checked if this is possible but also haven't tried the baby wipes yet as waiting until the marks bother me too much to ignore
edit - found the thread http://www.fullfatrr.com/forum/topic12532....p;start=30
also realised I had checked whether it affected the dual-view and the member who tried it said no difference so this may work! MY11 Vogue 4.4 TDV8 - "African Queen"
Post #258213 8th May 2014 12:17pm
ebajema
be careful with solvents, I suggest using microfibre cloth (dry) or special screen wet wipes. Replacing the screen I don't think is an option as far as I know. MY 2010 5.0 SC Galway green and sand interior!!
Post #258236 8th May 2014 1:53pm
mzplcg
Will try the baby wipe trick then. I've heard that before now I come to think of it. Thanks Chaps.
Post #258248 8th May 2014 2:34pm
shalz
let me know if it works for you as well as I might actually try it then MY11 Vogue 4.4 TDV8 - "African Queen"
Post #258272 8th May 2014 3:56pm
I use a micro fibre cloth, seems to work ok. Discovery 4 HSE
Post #258273 8th May 2014 3:59pm
markcartlidge
Your only hope is the polish out the marks ( difficult without damaging the front surface as it is usually some for of polyester. Consumer based product usually has resistive touch screens which have a substrate (glass) costing with a fine layer of conduction material (Indium Tin Oxide), the top layer is some form of flexible plastic also coated with ITO and the are small spacers between the two layers to kepp them seperated. They essentially work like a wheatstone bridge where one layer is X and the other layer is Y. When they contact you can calculate the position, commonly know as 4 wire sensors. 5-wire sensors have the x and y and the lower layer and the top membrane is a common plane. Modern products such as iphone etc use what is know a Projective Capactive touch sensors but that is a whole differnt subject.
If you can dissassemble the head unit you may be able to remove the sensor from the LCD and replace the sensor but depending upon age it may be difficult to obtain. If you can find out the make and model I might be able to source some from the far east.
Post #258280 8th May 2014 4:51pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
That'll be me then Whistle
The supplied micro fibre cloth does a good job of cleaning finger prints off the screen but if the film is scratched or marked, as mine was, no amount of rubbing would get rid of the coca-cola splash marks left by the careless first owner of my car Big Cry
I though the only option was a new screen but with the usual silly Land Rover prices (£1,800 as I recall Shocked ) as the dealer wouldn't replace it under warranty drastic action was required.
The baby wipe solution does in principle go completely against the grain of what is recommended as it does remove this film layer over the screen BUT I can assure you it has no effect on the viewing pleasure with or without duel view. I now find I use the micro fibre cloth a little more to keep the screen clear but only because I'm a fussy git about a nice clear screen Embarassed
So in summary, if you have just finger prints on the screen stick with the supplied cloth but if you have marks in the film that do not rub off with the cloth and you feel this to the detriment of your viewing experience then I cannot recommend baby wipes enough! They're pretty good at cleaning marks off the leather and door panels too Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #258281 8th May 2014 4:55pm
Ajay(UK)
markcartlidge wrote:
Your only hope is the polish out the marks ( difficult ..............
Blimey I thought I was reasonably intelligent but I have absolutely no idea what you are talking about Rolling Eyes Rolling Eyes Rolling Eyes
.................. or baby wipes then Rolling with laughter 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
Post #258283 8th May 2014 4:58pm
markcartlidge
We all have our areas of expertise. This is one of mine. If you were to ask how to dismantle the dash board I would be at the back of the queue Thumbs Up
Post #258286 8th May 2014 5:16pm
mzplcg
Final update on this. Baby wipes work like a champ. See below. 1st photo is after half a dozen horizontal wipes and you can see the stuff cleaning through the film/coating and leaving a clear screen behind. Photo 2 is the finished job and the screen is now nicely sans fingerprints.
What it appears to be is an anti-glare film but it wears through with being touched. Kind of self defeating really on a touch screen. There doesn't appear to be any more glare once it's cleaned off though so I'm a happy boy.
Post #259773 16th May 2014 7:01pm
Googsy
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #259791 16th May 2014 8:27pm
shalz
Glad it worked , looks much better. Will do mine soon. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #259836 17th May 2014 12:00am
Andy B
Thats a top tip Dom, will do mine this weekend.
Cheers,
Andy Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #259873 17th May 2014 8:43am
i kinda think its obligatory to have a packet of baby wet wipes in the FF..
always useful for cleaning the leather ,steering wheel etc and of course the lcd screen.. ... - .- -.
Post #259875 17th May 2014 9:02am
