![]() | Home > Technical (L322) > dual-view touch screen |
An off the wall question but is it possible to replace the front face of the touch screen? (without replacing the whole unit)
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
I can't find the post but I seem to recall that someone here noted that on the dual-view, the screen had an extra "film" layer over the screen which gave rise to the permanent fingerprints, and this could be removed by using baby wipes or some sort of flash wipe equivalent. This got ride of the extra film and made the screen easier to clean, although not sure if this affected the dual-view function or not.
Will try the baby wipe trick then. I've heard that before now I come to think of it. Thanks Chaps. |
let me know if it works for you as well as I might actually try it then MY11 Vogue 4.4 TDV8 - "African Queen" |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
I use a micro fibre cloth, seems to work ok. Discovery 4 HSE
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
Your only hope is the polish out the marks ( difficult without damaging the front surface as it is usually some for of polyester. Consumer based product usually has resistive touch screens which have a substrate (glass) costing with a fine layer of conduction material (Indium Tin Oxide), the top layer is some form of flexible plastic also coated with ITO and the are small spacers between the two layers to kepp them seperated. They essentially work like a wheatstone bridge where one layer is X and the other layer is Y. When they contact you can calculate the position, commonly know as 4 wire sensors. 5-wire sensors have the x and y and the lower layer and the top membrane is a common plane. Modern products such as iphone etc use what is know a Projective Capactive touch sensors but that is a whole differnt subject.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
That'll be me then |
Blimey I thought I was reasonably intelligent but I have absolutely no idea what you are talking about ![]() ![]() ![]() .................. or baby wipes then ![]() SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
We all have our areas of expertise. This is one of mine. If you were to ask how to dismantle the dash board I would be at the back of the queue |
Final update on this. Baby wipes work like a champ. See below. 1st photo is after half a dozen horizontal wipes and you can see the stuff cleaning through the film/coating and leaving a clear screen behind. Photo 2 is the finished job and the screen is now nicely sans fingerprints.
Glad it worked , looks much better. Will do mine soon. MY11 Vogue 4.4 TDV8 - "African Queen" |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Thats a top tip Dom, will do mine this weekend.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i kinda think its obligatory to have a packet of baby wet wipes in the FF..
