![]() | Home > Technical (L322) > global closing with keyfob |
My car doesnt appear to have global closing function when using keyfob. Is this something I can enable with iid tool?
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 391 ![]() ![]() |
Excuse my ignorance, but what is global closing?? Do I have it on my 2011?? Thx! |
Ability to open and close all windows by pressing and holding keyfob |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
Mine has it, but I'm sure it was an option on IIDTool.
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
My 56 plate X-Type had that - and so does my FFRR http://www.fullfatrr.com/forum/post258494.html#258494 Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
My 2002 has it, but my 2007 has not. |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
@Robert - it has it- have to ask dealer or person with IIDtool/similar to activate it. When I got my car, it also did not have it; dealer then activated it. |
Thanks vnitos |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Pop your ignition key in the door and lock the car then turn the key back half way to the original position and the windows should then open and visa versa to open them...
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Yes Robert, you will need the tool |
Thanks guys |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
IID seems to get all the good press. I have one, but I'm right at the beginning if the learning curve. |
