Home > Technical (L322) > global closing with keyfob
Googsy
My car doesnt appear to have global closing function when using keyfob. Is this something I can enable with iid tool?
My neighbours 97 nissan almera has it Big Cry
Thanks Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #258500 9th May 2014 9:46pm
Think mine does it....... There is nothing that can't be fixed with a hammer😜😜
Post #258502 9th May 2014 9:51pm
funnyguy1
United States
Excuse my ignorance, but what is global closing?? Do I have it on my 2011?? Thx!
Post #258505 9th May 2014 9:57pm
Googsy
Ability to open and close all windows by pressing and holding keyfob Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #258506 9th May 2014 10:06pm
Mine has it, but I'm sure it was an option on IIDTool.
You have to hold to button down for quite a while before it works mind you. Got - 2017 SDV8 Autobiography in Loire Blue
Post #258509 9th May 2014 10:33pm
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Re: global closing with keyfob
Thanks Thumbs Up
My 56 plate X-Type had that - and so does my FFRR
http://www.fullfatrr.com/forum/post258494.html#258494 Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #258518 9th May 2014 11:22pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
My 2002 has it, but my 2007 has not.
Post #258521 9th May 2014 11:36pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
@Robert - it has it- have to ask dealer or person with IIDtool/similar to activate it. When I got my car, it also did not have it; dealer then activated it.
Post #258531 10th May 2014 5:20am
Robert
Thanks vnitos Thumbs Up Ithought so, got to buy that tool.
Post #258545 10th May 2014 8:32am
Pop your ignition key in the door and lock the car then turn the key back half way to the original position and the windows should then open and visa versa to open them...
The IID will allow this function to work with the remote too Thumbs Up
Post #258563 10th May 2014 9:38am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Yes Robert, you will need the tool Thumbs Up Thumbs Up
All kinds of options were disabled on my FF when I got it, Big Cry but I had to send it to a stealer to have a problem with the engine ECU map sorted out, and i got them to enable all the facilities as I wanted them while they had the car. Very Happy
But an IID tool would be good, because then you could set these things up for yourself. Very Happy
also, probably 2 hours at stealer labour rates, and your tool has paid for itself. Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #258564 10th May 2014 9:39am
Robert
Thanks guys Thumbs Up Which tool is the best one for a non tech?
Post #258579 10th May 2014 11:01am
RR2008HSE
IID seems to get all the good press. I have one, but I'm right at the beginning if the learning curve.
Post #258654 10th May 2014 9:25pm
