![]() | Home > Technical (L322) > brake pad warning light on |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Depends how much braking you do |
If its the rears gone and you have a rear calliper issue then it could be just a few miles! I have seen the rears go from good pads to discs ruined in under a hundred miles!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
might be worth replacing the discs when you do the pads... ... - .- -.
Craig is right, if the calipers are having the notorious stuck caliper issue your pads are gone in no time. Although you would notice this during driving I expect and check the wheels after a shortish drive from cold and if they or one are/is piping hot, you know the caliper is a problem.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
Cheers guys
