Home > Technical (L322) > brake pad warning light on
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
The "check brake pads" warning light has come on, can anyone tell me roughly how long I've got, before it's down to the metal? The car is booked in to my Indy friday, for new pads all round, New rear callipers, sensors, and fluid change. Trying not to use the car to much, but my parents are coming over for a few days this week, and its the only car we have big enough to pick them up, and take them about in, bloody typical, always a problem when you really need the car!
Post #258677 11th May 2014 5:39am
Depends how much braking you do Razz
Brembo discs are actually cheaper than I expected - £59+VAT each from Dan
You will of course need a new sensor now, so better make sure the Indy has one of those too.
I would have thought a few days careful driving should be OK - a bit like driving with the fuel light on.......
Post #258681 11th May 2014 8:20am
If its the rears gone and you have a rear calliper issue then it could be just a few miles! I have seen the rears go from good pads to discs ruined in under a hundred miles!!! Shocked
Ya pays yer money.... Ya takes yer chance sir Bow down Whistle Thumbs Up
Post #258700 11th May 2014 9:42am
might be worth replacing the discs when you do the pads... ... - .- -.
Post #258701 11th May 2014 9:45am
ebajema
Craig is right, if the calipers are having the notorious stuck caliper issue your pads are gone in no time. Although you would notice this during driving I expect and check the wheels after a shortish drive from cold and if they or one are/is piping hot, you know the caliper is a problem.
At normal wear you should have no problem to reach the end of the week safely. MY 2010 5.0 SC Galway green and sand interior!!
Post #258703 11th May 2014 9:52am
SFM
Cheers guys
Am replacing both callipers as a precaution anyway, it hopefully is just down to normal wear, they are a heavy old lump.
Post #258706 11th May 2014 10:02am
Post #258707 11th May 2014 10:03am
