Home > Technical (L322) > Rear Arches Bubbling!
BigPete
United Kingdom 2011 Range Rover Autobiography TDV8 Fuji White
Not a very exciting title to a thread, but here goes...
Noticed some very slight bubbling to both the rear arches, bloody annoying that.... Evil or Very Mad So took it and booked it in for paint at the local bodyshop. He's done a few of these with exactly the same problem and apparently, the drain holes for the sunroof might be blocked Question therefor water is finding its way down to the rear arches. Shocked Shocked
I know water ingress comes in from the rear windows and that was where i was going to go first...
Anyone know where the said sunroof drain holes are?? Dont really want to be painting it twice do we........ Big Cry 2011 TDV8 Autobiography
Post #259758 16th May 2014 5:38pm
mjdronfield
Well, have look at my thread regarding this
http://www.fullfatrr.com/forum/topic9387.h...wheel+arch
Had it stone chipped by the Bodyshop and put rubber protectors on to stop it happening again.
This is the only fix I know. Not had an issue since.
Don't know anything about sunroof drains causing it though.
I assume you meant on the lip of the wheel arch.......? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259760 16th May 2014 5:50pm
BigPete
I'll nip out and take a pic.... Idea
Pete 2011 TDV8 Autobiography
Post #259761 16th May 2014 6:02pm
BigPete
Both rear arches.... Big Cry
Post #259763 16th May 2014 6:14pm
mjdronfield
Ah. More in the visible area then.....
Not a bodywork expert, but I'd guess it's better to catch it early and get it corrected.
See you have some arch lip protectors on.
It could have been repaired already judging by how badly protected that area is. Only the Bodyshop will be able to tell you when they do this repair.
I mean badly protected from the factory, not on your rr specifically........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259765 16th May 2014 6:27pm
It could be worse:
Must get this sorted !! Embarassed .
Post #259769 16th May 2014 6:48pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine are bubbling too Big Cry
Mind you it is 12 years old now, so probably to be expected.
Post #259770 16th May 2014 6:50pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Mine too. Gonna tackle them in the next few weeks now it's warming up. Still not sure which rust convertor to use. I plan on grinding out as much of the rust as possible first.
Post #259787 16th May 2014 8:15pm
BigPete
Would all this bubbling have anything to do with the water ingress through the 2 rear side windows? Idea The same ingress that knackers your nokia bluetooth module up? Question 2011 TDV8 Autobiography
Post #260375 19th May 2014 8:51pm
I think you are spot on with the idea this is connected with water ingress to the rear compartments.
Any water that gets into the car sits in the bottom of each side and gradually causes the panel to corrode and eventually perforate causing the bubbling you have. When I got my car water tight by fitting a new tailgate seal I made a point of taking out all the bits I could in order to get access to apply a thick layer of grease to the inside surface of each of the panels to inhibit corrosion. So far no corrosion.
Post #260383 19th May 2014 9:11pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Shocked
Thankfully my arches aren't no where near as bad as those Joe has, just the lip had a little rust ( now sorted ) Mr. Green
Its my top tail gate just starting to bubble up on one corner! If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #260387 19th May 2014 9:18pm
