![]() | Home > Maintenance & Mods (L322) > rear arch lip. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
You need to put rubber protectors on the lip now.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
I got a plastic lip seal watching on ebay at the mo, but yes, will go the same if not carful |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
That looks more like the stuff you put on the edge of the door to stop you banging it on the wall......
I got mine from the local dealer, as they had them in stock and I was driving past.
I've had the plastic strip as above fitted for 3 years now and still no corrosion on the rear wheel arches. I applied a thick coating of grease to both sides of the lip before fitting the strip and then wiped the excess off. I remove the strip each year and clean and re-apply the grease. Seems to work. |
Fine.........FINE.........you keep your plastic strips from a 1974 Mk3 Ford Cortina door edge and I shall take my "must be better as it says Land Rover on them" rubber strips and go and stand where someone loves me |
Who rattled your cage. |
Good. Glad we cleared that up....... |
now now children, its only its only a plastic strip ! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
He started it |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Stan will be smacking the back of somebody's legs |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Metaphorically speaking I hope |
