Home > Maintenance & Mods (L322) > rear arch lip.
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
rear arch lip.
Well been waiting for a nice day and nothing to do on the house ( yea right if only!) I thought better sort out the lip on the rear arches, as others have done in the past, but in all honesty mine weren't too bad for a 11 year old!
Both sides rust killed treated and 2 coats of black satin paint, should last a bit now!
oh and yesterday, clear indicator lights repeaters fitted from hawke ....hmmm modern now Rolling with laughter
 If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #259804 16th May 2014 9:23pm
mjdronfield
You need to put rubber protectors on the lip now.
Will happen again if you don't. The flimsy thing on the rear door isn't enough IMHO.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259860 17th May 2014 7:05am
Welshdragon
I got a plastic lip seal watching on ebay at the mo, but yes, will go the same if not carful Thumbs Up
I guess you got yours from Dan?
This is what Im looking at.
http://www.ebay.co.uk/itm/170905661089?ru=...26_rdc%3D1
As per Nicedayforit Thumbs Up
http://www.fullfatrr.com/forum/topic22530....wheel+arch If it dont work.......burn it!
Post #259869 17th May 2014 8:07am
That looks more like the stuff you put on the edge of the door to stop you banging it on the wall......
The stuff from LR is only a few quid an is wide enough, and rubber with metal in it so it stays on well.
Meant for either a ssrr or freelander I think but works perfectly! Better option all round Thumbs Up dan can supply Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #259880 17th May 2014 9:28am
mjdronfield
I got mine from the local dealer, as they had them in stock and I was driving past.
I'm sure I got 4 of them, for less than £5 each.
The longer ones are cheaper than the shorter ones. They were never fitted to the L322, which was obviously a big mistake.
I didn't want a join on the car, so got 4 and cut to length to suit.
Entire rear wheel arch lip covered now.
Very happy. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259881 17th May 2014 9:39am
I've had the plastic strip as above fitted for 3 years now and still no corrosion on the rear wheel arches. I applied a thick coating of grease to both sides of the lip before fitting the strip and then wiped the excess off. I remove the strip each year and clean and re-apply the grease. Seems to work. Thumbs Up
The plastic strip is the type used for protecting the edges of doors but works very well and unlike the LR product has no metal in it to corrode. Looks very professional fitted.
I also fitted the plastic strip to my daughters Freelander in place of the LR product that corroded and fell off.
Post #259882 17th May 2014 9:41am
mjdronfield
Fine.........FINE.........you keep your plastic strips from a 1974 Mk3 Ford Cortina door edge and I shall take my "must be better as it says Land Rover on them" rubber strips and go and stand where someone loves me Rolling with laughter
To be fair, as long as its stops the rust and doesnt look an Censored fitted, job done.
The metal strip in the LR rubbers are supposed to help it keep its shape and stay in place, but having had mine on for a couple of years, I can't comment on long term metal strip corrosion issues.
Are the plastic ones wide enough ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259886 17th May 2014 10:12am
Who rattled your cage. Rolling with laughter
Yes the inferior to LR products plastic strips are wide enough.
Post #259896 17th May 2014 11:33am
mjdronfield
Good. Glad we cleared that up....... Laughing
The door edging will be easier to trim to length, and if it's that cheap for a big loop of it you could find other uses for it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259900 17th May 2014 11:38am
Welshdragon
now now children, its only its only a plastic strip ! Rolling with laughter Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #259959 17th May 2014 6:56pm
He started it Rolling with laughter Rolling with laughter Rolling with laughter .
Post #259983 17th May 2014 9:57pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Stan will be smacking the back of somebody's legs Rolling with laughter Rolling with laughter 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #259991 17th May 2014 10:29pm
Metaphorically speaking I hope Laughing Laughing Laughing
Post #260007 18th May 2014 1:11am
