Home > Maintenance & Mods (L322) > Key won't turn in ignition
Duke Thrust
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Arrghh!
Second problem of the day!
2007 FFRR supercharged (key in dash)
The key won't turn in the ignition barrel, I can hear a fait whur whur noise from the steering column but the lock doesn't disengage and you also can't turn the key.
The battery is fully charged and I even hooked up another just in case but no joy.
Any thoughts?
Post #260347 19th May 2014 7:17pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
pretty sure it's the ecu on the steering column is knackered. comes as one complete unit Big Cry 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #260352 19th May 2014 7:37pm
Playsatan
The transponder chip is needed to in the key, have you had it recut.
Also, I take it you're in park?
Post #260354 19th May 2014 7:38pm
Duke Thrust
In park and same result with both keys.
Steering column and ecu sounds expensive...
Post #260358 19th May 2014 7:44pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Not sure if this is relevant. There is a linkage cable that causes issues with key if not operatiing correctly.
If you type "ignition key" into search on forum, there are several threads regarding the issue, with some suggesting this and others electronic
http://www.fullfatrr.com/forum/post87201.html#87201
Edited...damn text autocorrection! GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #260360 19th May 2014 7:49pm
this might help,
http://www.fullfatrr.com/wiki/Key_stuck_in_ignition ... - .- -.
Post #260363 19th May 2014 7:54pm
Duke Thrust
Thanks guys, the key's not stuck in the ignition, more that you can put it in, but not turn it.
I think the mechanism is sticking as I can hear a repeated whirring sound for a few seconds and if I time it right I can turn the steering wheel but still not the key though.
I'm wondering if it might be this (below), although it seems to be for the earlier car, is the steering column the same?
http://www.blackbox-solutions.com/photos/L322lock.pdf
Post #260380 19th May 2014 9:05pm
paulmoran2
On my 2007 (ignition in dash) I sometimes have it lift the key fob slightly to get it to turn ...just another thought before spending any money GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #260382 19th May 2014 9:11pm
Duke Thrust
After some experimentation this morning I've discovered that if I time it right, between the whur-whuuuuur noise I can get the key to turn with a bit of pressure - about 50% of the time.
It feels like something is trying to move/release but not quite managing it.
Getting closer to drilling that hole I think.
Post #260426 20th May 2014 7:36am
There are several linked ECU's that the key communicates with and every one has to return the correct response.
Most good indies can check wiring and know which one to replace first on a trial and error basis.
Check codes see if you get a "Car lost communication with Dashboard" type code
PS: Doing a hard reset may clear the intermittent ECU fault and let you start the car.
Post #260449 20th May 2014 8:37am
