Home > Maintenance & Mods (L322) > Auto 'dipping' passenger wing mirror?
Page 2 of 3 <123>
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
..............anyway instructions are on the top of the sun visor Smile 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #261346 25th May 2014 11:02am
Jonno
.........................so how many thought "I don't remember seeing that" .............and went out to check Rolling with laughter 5.0 supercharged autobiography
Post #261349 25th May 2014 11:56am
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Tried setting this up today and I cannot get it to work - it's either broken or my car doesn't have the feature Whistle
Any ideas? Now I have it in my head I need to get this set up or fixed Rolling with laughter Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #261505 26th May 2014 5:08pm
You have to store the "up" position of the mirror and the "down" position of the mirror using the seat memory button.
The procedure is exactly the same as setting seat positions or steering column positions.
It's all in the handbook. Thumbs Up
Post #261509 26th May 2014 5:47pm
Jonno
Ok try again. Set the seat and mirrors to your desired positon enter into seat memory 1, now push the mirror switch towards the drivers side mirror, select reverse and hey presto. 5.0 supercharged autobiography
Post #261510 26th May 2014 5:53pm
Jonno
................Previous posts are what happens when you have more than one model of Range Rover Whistle 5.0 supercharged autobiography
Post #261512 26th May 2014 5:54pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Jonno wrote:
Andy, you need to tell the mirror what position to be in.
Start car
Select reverse
make sure mirror switch is towards you
manually move mirror to desired position
select park
turn off ignition
jobs a good un......................................................me thinks
Jonno
That didn't work on mine Rolling Eyes
Post #261528 26th May 2014 7:04pm
mjdronfield
Not much in my manual ;
Not sure if it will dip so long as you have the return position in memory.
Seems strange it works on some and not others...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #261531 26th May 2014 7:22pm
Well it works on mine ok. Laughing
I set mine by using the memory function on the seats as per setting a seat position.
Post #261559 26th May 2014 8:53pm
andy180
Ok so I set the seats various times and my passenger mirror doesn't seem to move at all with the memory buttons Rolling Eyes When I change the seat position the steering wheel moves, the seat moves, the drivers mirror moves..... but the passenger mirror doesn't Whistle I can only assume this is something to do with why my mirror is not dipping Big Cry Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #261618 27th May 2014 9:00am
If I get time this morning I will check the procedure I used on my car and post it for you so you can try what works for me. Thumbs Up
Post #261621 27th May 2014 9:11am
iphs
I look forward to that Thumbs Up
Related to that. My seats dont appear to adjust from the keys, only from the memory buttons. Confused
Post #261622 27th May 2014 9:20am
Right this is how I do it and I've just checked and it works ok on my car.
The first thing you need to do is check that the passenger side mirror can actually be adjusted ie does the mirror glass move when you change it's position using the controls on the drivers door panel.
If it does move ok, if it doesn't move the chances are the motors are seized with lack of use.
Assuming the mirror glass moves.
Switch on ignition.
Using door panel controls set mirror to desired upper position.
Press "M" button on seat, switch should illuminate.
Press "M1" button on seat within 7 seconds.
That mirror position is now stored.
Put gear lever into Reverse.
Using door panel controls set mirror to desired lower position.
That should be it. Thumbs Up
To check the mirror moves down when reverse is selected put car in "P" the mirror should drive to upper position.
Move mirror selector slider switch on driver door panel to Right ie drivers side mirror and select reverse, the passenger door mirror should now dip to lower selected position.
Selecting reverse and park, the passenger mirror should drive up and down according to gear lever position.
Also, if in reverse with the mirror in the lower position, if you move the mirror selector slider switch on the drivers panel
to the left ie passenger side mirror the passenger door mirror should drive up to the upper position.
In addition the Memory positions for the seat, mirrors and steering column should operate when you press the fob to unlock the car for each individual keyfob, provide of course the settings have been stored in the memory for each key.
I hope this works for you. Smile
Post #261650 27th May 2014 2:14pm
andy180
Nice day for it thank you for your detailed response. I've been out and tried that a few times now and it definitely isn't for working. The mirror is operational with the door pack and the motor seems to be perfectly strong and operates as it should. As do my memory settings otherwise and I have the switch in drivers position Whistle Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #261702 27th May 2014 6:57pm
Jonno
absolutely brilliant................. 5.0 supercharged autobiography
Post #261705 27th May 2014 6:59pm
Page 2 of 3 <123>
