![]() | Home > Maintenance & Mods (L322) > Auto 'dipping' passenger wing mirror? |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
..............anyway instructions are on the top of the sun visor |
.........................so how many thought "I don't remember seeing that" .............and went out to check |
You have to store the "up" position of the mirror and the "down" position of the mirror using the seat memory button.
Ok try again. Set the seat and mirrors to your desired positon enter into seat memory 1, now push the mirror switch towards the drivers side mirror, select reverse and hey presto. 5.0 supercharged autobiography
................Previous posts are what happens when you have more than one model of Range Rover |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
That didn't work on mine ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7961 ![]() ![]() ![]() |
Not much in my manual ;
Well it works on mine ok. |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
Ok so I set the seats various times and my passenger mirror doesn't seem to move at all with the memory buttons |
If I get time this morning I will check the procedure I used on my car and post it for you so you can try what works for me. |
I look forward to that |
Right this is how I do it and I've just checked and it works ok on my car.
Nice day for it thank you for your detailed response. I've been out and tried that a few times now and it definitely isn't for working. The mirror is operational with the door pack and the motor seems to be perfectly strong and operates as it should. As do my memory settings otherwise and I have the switch in drivers position |
absolutely brilliant................. 5.0 supercharged autobiography
