Home > Maintenance & Mods (L322) > Newbie. Bit of help needed please
You should have the bonnet up whilst waiting for the car to go to sleep... Not after it has gone to sleep (otherwise the opening bonnet may wake the systems up again!
Simply remove the earth lead off the battery... Its just a 10mm spanner... Thumbs Up
Post #261408 25th May 2014 11:03pm
MikeT
Russia
ok cheers for that
I get the feeling as my suspension fault message is not a real problem. As whenever I get the message all I have to do is switch off the engine. re-start and all is fine again.
So if I open the bonnet, take off the earth lead, re-connect, turn my steering wheel left then right and after this I still get the error message - what are my next steps?
It's just more irritating than anything else
Post #261424 26th May 2014 6:48am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
If the message keeps coming up after disconnecting and then reconnecting the battery, then turning the steering wheel full lock from left to right then it looks like maybe the battery is on its way out. It does not take much of a drop in voltage performance for it to affect the basic diagnostic messages from the ECU.
If the car suspension works fine but the message comes up, then it is more than likely time to plan for a new battery. Most on here go for the Bosch (or Varta) S5 110a which is a tight fit but gives you the most powerful battery possible and a long warranty.
Obviously there may be another issue hidden away, but I have had the same message as have many on here and it disappeared when a new battery was fitted. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #261437 26th May 2014 9:11am
ebajema
AFAIK the 2006 MY SCs don't need the steering wheel trick anymore, anyway I never used it and my battery has been disconnected many times.
So suggest to remove the negative lead and leave it of for some time, i.e. an hour or so. Then each ECU will power down completely and the transient faults should be gone.
Also, have you tried just lower the car all the way, raise it to max and see if it sees the error of its ways ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #261443 26th May 2014 10:25am
MikeT
Russia
thanks guys
I'll try leaving the Neg off for an hour or so and see if that does the trick
ebajema - yes I've lowered and raised it several times to the point that I felt like i was in a rap video Very Happy
still didn't do it. So neg off for an hour if not I suppose it's a new battery
Post #261444 26th May 2014 10:39am
Have you had the fault codes read? Sounds like either a battery issue or a faulty height sensor... Fault codes will rule out the latter Thumbs Up
I don't know your situation (dealer locations, garages or your own level of expertise) but i can fully recommend the iid tool for fault finding these types of issues... A couple of hundred quid = a more stress free owner Thumbs Up Thumbs Up Thumbs Up
Post #261457 26th May 2014 11:24am
MikeT
Russia
Craig
My level of expertise = nada
Plus I live in Russia so getting anything done is always difficult. Think I'll leave the neg connector on my battery off for an hour and try that. If no success then I will go and get my fault codes read and see what that shows
If it is a height sensor issue approximately how much should cost inc fitting? ( I understand moscow prices will vary)
Post #261480 26th May 2014 1:40pm
MikeT
Russia
ok guys another question
I've got the extra dongle thingy that allows me to start the engine remotely.
When I bought the car the battery in the fob was dead. I've just replaced the batteries but it still doesn't work - does the unit need pairing with something again since having flat batteries?
Thanks
Post #261861 28th May 2014 2:21pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
If you mean the remote for the fuel burning heater, yes it does need pairing - see this thread Thumbs Up
http://www.fullfatrr.com/forum/topic5923.h...fbh+remote 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #261862 28th May 2014 2:25pm
MikeT
Russia
thanks for the swift reply - I'll have a go at that over the next day or 2# Very Happy
Post #261865 28th May 2014 2:50pm
Prop
And just to clarify the fob will not start the engine for you but will start the fuel burning heater, this will preheat the cabin, but be careful as if your battery is not in tip top condition it will flatten your battery and you will not be able to start your engine. You only really need this function in cold weather.
Post #261870 28th May 2014 3:11pm
MikeT
Russia
Prop
Ahh thanks for that, Thumbs Up I would have been expecting the engine to start. Moscow gets down to about -30 degrees in the winter so I guess this should qualify as cold weather
Post #261877 28th May 2014 3:24pm
MikeT
Russia
Nice one. Got my pre-heater all working Thumbs Up
Now 1/2 way thru changing the battery pack on my venture cam Smile
Post #261950 28th May 2014 7:44pm
