![]() | Home > Maintenance & Mods (L322) > Lumpy ride and car vibration |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
To actually knock your steering wheel out of centre something has to move...... Get them to check the integrity of the inner and outer track rod arms it may be possible that one bent in the impact, cheap enough to repair, but for the tracking to immediately go so far out that the wheel was off centre surely means that something is bent, possibly the inner track rod/axial tie rod.
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Have you considered a different dealer for an inspection?, mine goes to LR Kortrijk [as well as Sussex, UK] |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
I'd put 2p on it being the tyre that hit the ladder, they can have serious sidewall damage and it will show on the inside not the outside, will balance ok and look fine at rest but at 70mph it's under a lot of strain...
And as has been said, you can't knock the tracking out, it's adjusted by a threaded rod, to put the steering wheel out you have bent something and they have compensated by adjusting the tracking, just because the wheels now point in the right direction doesn't mean nothings bent
expatmarais Member Since: 20 May 2014 Location: OH Posts: 19 ![]() ![]() ![]() |
Hi thanks for your replies and advice.
The bend could be very slight and also in more than one part, they should be able to find it but if they can't it may mean a trip to a jig to get it checked, if this is the case I would defo get your insurance company involved as it could cost mega bucks,
Very happy with LR Kortrijk. They supplied my beast and 250k on they have done all except 1 service. I also use a place in Sussex for other bits.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Please make sure you put your safety first... If putting car in off road height and clambering around underneath then please put preferably a set of axle stands. If not, at least your spare wheel under the corner closest to you! As the suspension bags are under a lot of pressure and a failure could squash/injure you, if not worse!!! Not trying to scare anyone. But do the safety stuff please... |
Well Noted CamtechCraig - I will be looking at with LR Dealer on his ramp and after having seen the pathetic jack decided not to change wheel myself after all.. |
Final update:
glad its sorted.. |
Oh, I like being right, doesn't happen that often!!!!!
^ Ask my Mrs for some tips. She's always right |
Sorry to say there was a relapse..
