Home > Maintenance & Mods (L322) > Torque converter ???
Torque converter is screaming at me, sounds like a strangled bird in there, at least I presume it is, does it when it gets hot and does it in drive and neutral when stopped...
Anyone know anywhere that rebuilds them rather than just buying a new one
Had heard Huddersfield automatic transmissions are good but never used them
Typically there are no specialists on Hull that I know of..... Pete
-Click here for Thread-
Post #262398 31st May 2014 6:23am
RRPhil
Remanufacturing the Sachs W260S-2GWK torque converter is a specialist task : http://www.fullfatrr.com/forum/post186323.html#186323
I personally would only trust someone like JPAT (www.jpat.co.uk) or Sussex Auto Parts (www.sussexautos.co.uk) who both have a lot of experience with this particular unit.
Phil
Post #262433 31st May 2014 9:45am
Thanks Phil I'll ring them... Pete
Post #262435 31st May 2014 9:55am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I used Sussex Auto Parts last month for my TC after seeing RRPhil recommend them in another post (thanks RRPhil Thumbs Up ).
They were very helpful and went out of their way to provide me with an off the shelf recon unit instead of me having to go back and collect mine and even knocked some money of the quoted price on the phone (quoted £180+VAT). They can do a while you wait rebuild if you want which takes a few hours. Obviously a bit out of the way for you but they do a fast postal service which means a 3 day turnaround (they quoted if got TC on a weds I should get it back Fri).
They turn around a lot of TC's which are rebuilt in house. They regularly get in shipments of 70+ allsorted TC's to rebuild from one customer in Germany. While I was there they were doing a Autobox rebuild training course so obviously know their stuff.
One thing they did ask when I rang up was what was the code on the TC so they can check stock...something you can't see until you take the TC out. Anyway for the BMW 4.4l with ZF 5HP24 like yours the code is F38.
While in there it's worth replacing the transmission input shaft seal and also the crankshaft rear main seal, I replaced both mine (main seal was weeping). It's also a ideal time to do the coolant hoses at the top back of the engine.
P.S. if you are removing the gearbox without help (or even with it) then split the transfer box off the back and remove separately, it makes the whole process a lot easier. There is no gasket to worry about between the two.
Remember to fill the TC with some fluid before mounting it otherwise it's dry from startup.
Post #262438 31st May 2014 10:25am
Thanks chaps,
I feel a bit of a Censored now..... It was an intermittent noise, and I couldn't get it to do it with the bonnet up!!
It sounded just like the noise when I had a convertor go on a previous car,
Anyway after a bit more driving it has got a lot worse and is screaming like a goodun...
It now appears to be the water pump bearing, the pulley is wobbling and the noise is defo from that area...
Never had a pump sound like that before, I've ordered one and it will be here Tuesday, hope it lasts...
The only other thing it could be is the timing chains but I don't think they'd sound like a strangled cat??? Pete
Post #262440 31st May 2014 10:37am
Weejock
Updated transmission removal procedure (not as per the workshop manual), see post no 45 (by RRPhil again Thumbs Up):
http://www.rangerovers.net/forum/6-range-r...ode-3.html
If you can't download them let me know and I'll email them over.
Post #262441 31st May 2014 10:38am
Weejock
If the water pump is sounding that bad it's probably on it's last legs and the bearing is shot.
If it's wobbly it's knackered. Worth checking the tensioners too, they can scream like a good'en if their bearings are shot.
I wouldn't recommend driving it like it because if it lets go completely the belt may snap or slip off and can take out other expensive bits like the radiator. Up to you though, water pumps have a nasty habit of their bearings seizing solid and snapping belts once worn and wobbly.
Easy way to check if it's the water pump is the culprit of the noise is to remove the water pump belt then briefly run the engine.
Post #262442 31st May 2014 10:47am
Cheers, I've ordered a new pump, belts and coolant and I'll take it home when I finish work, only 7 miles and it can have a rest and I'll get the Sunday car out till it's done.... Pete
Post #262453 31st May 2014 11:11am
Well it got 3 miles home and it's seized and shredded the fan belt, now waiting for the recovery truck
Oh well, cheaper than a torque convertor....!!!! Pete
Post #262457 31st May 2014 12:57pm
Yep, think that's knackered.....
 Pete
Post #262495 31st May 2014 6:21pm
Yep thats bust that is Whistle There is nothing that can't be fixed with a hammer😜😜
Post #262497 31st May 2014 6:31pm
Think might need a bit of gaffer tape to sort out the drive belt as well
 Pete
Post #262502 31st May 2014 7:36pm
Shocked
I had an air con compressor implode on me one time in a bmw, smoke coming from under the bonnet etc There is nothing that can't be fixed with a hammer😜😜
Post #262503 31st May 2014 7:51pm
Weejock
Censored Unlucky, Sods Law! I would have done the same for sake of 7 miles.
Yep, look on the bright side, it's a lot cheaper and easier to fix than a torque converter.
You could have done what I did, tracked a noise down to what you thought was the TC, gone to all the trouble, expense and effort of changing the TC only to find the noise still there afterwards... Big Cry lol!
Post #262504 31st May 2014 7:58pm
