![]() | Home > Technical (L322) > Fault Indications, guidance please. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Sounds like it could be an ABS sensor out or dodgy connection to one. Have a check of the wiring to the sensors for any splits or broken wires, and also that the plugs are ok.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Is the speedo working ?
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Is your steering wheel aligned, ie not off-centre? I had a similar issue due to this. 2007 TDV8 Vogue SE Java Black |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
Thanks for the replies fellas.
Did you have tyre and/or brakes done recently ?? Sometimes mechanics aren't that carefull and damage either a wheel speed sensor or ride height sensor.
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Another possible is the yaw sensor (in the center console) - if this goes open circuit that's the symptoms you'll get - could be fine when it's cold but intermittent open circuit as it warms up.
Thats interesting Stu1. |
If possible, get the codes read before it gets expensive replacing bits on a hunch/forum read |
As said, always get a code read before randomly replacing parts, it should pull up exactly which sensor is off line or faulty. Any good indy should do it for you at minimal cost. There is nothing that can't be fixed with a hammer😜😜
Cheers guys, I will get it to an indie and have that done as soon as I can drive again. |
