Home > Technical (L322) > Fault Indications, guidance please. |
Sounds like it could be an ABS sensor out or dodgy connection to one. Have a check of the wiring to the sensors for any splits or broken wires, and also that the plugs are ok.
1st Jun 2014 8:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Is the speedo working ?
1st Jun 2014 9:24pm |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
Is your steering wheel aligned, ie not off-centre? I had a similar issue due to this. 2007 TDV8 Vogue SE Java Black |
1st Jun 2014 9:29pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
Thanks for the replies fellas.
1st Jun 2014 10:38pm |
Did you have tyre and/or brakes done recently ?? Sometimes mechanics aren't that carefull and damage either a wheel speed sensor or ride height sensor.
1st Jun 2014 11:51pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Another possible is the yaw sensor (in the center console) - if this goes open circuit that's the symptoms you'll get - could be fine when it's cold but intermittent open circuit as it warms up.
2nd Jun 2014 9:46pm |
Thats interesting Stu1.
2nd Jun 2014 10:34pm |
If possible, get the codes read before it gets expensive replacing bits on a hunch/forum read
2nd Jun 2014 10:46pm |
As said, always get a code read before randomly replacing parts, it should pull up exactly which sensor is off line or faulty. Any good indy should do it for you at minimal cost. There is nothing that can't be fixed with a hammer😜😜
2nd Jun 2014 10:51pm |
Cheers guys, I will get it to an indie and have that done as soon as I can drive again.
2nd Jun 2014 11:01pm |
