![]() | Home > Maintenance & Mods (L322) > Rear window trim |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
Yep, warm it up first (hot water or hair drier),am good spray of silicone lube, and it should either slide out, or peel from one end. Have a look at the end of the trim and you can see it in profile.... |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Thank you sir!!! That'll save whipping the glass out! |
Quick work of warning... You will possibly have a line in your paintwork where the rubber has sat for years... 70% of those we have removed do |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Well this post has saved me from putting in a new post about the rubber on the back window. |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I ended up having to cut through one end of mine and then peeled the rest off. It has left a line where previously painted up to the trim rather than removing it but at least I found where the rust bubble kept coming from as there was a rusty unpainted spot under the trim about 1 1/2" long, which I have treated with stabilizer but no the dealer can repair properly as agreed and remove the paint line they caused by bodging the original repair (twice) There is a difference between knowing your sh!t and knowing you're sh!t
Cheers Craig, its coming off to get rid of some tiny bubbles in the paint so its all good. |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Just as Craig said. Mine slid out no issues, but left a line in the paint that won't tcut out. Accept, some days your the pigeon, some days your the statue! |
Cheers guys. Am I right in thinking the newer models don't have this trim? Just the side ones? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
06-09 dont have any trims
