Home > Maintenance & Mods (L322) > Rear window trim
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Rear window trim
Could anyone tell me if the lower black trim on the back window of the early 322's can be removed without taking out the glass?
Post #262859 2nd Jun 2014 11:12pm
tsadpt
Yep, warm it up first (hot water or hair drier),am good spray of silicone lube, and it should either slide out, or peel from one end. Have a look at the end of the trim and you can see it in profile....
Post #262863 2nd Jun 2014 11:48pm
paul271
Thank you sir!!! That'll save whipping the glass out!
Post #262867 3rd Jun 2014 12:25am
Quick work of warning... You will possibly have a line in your paintwork where the rubber has sat for years... 70% of those we have removed do Shocked
Just depends if that will bug you or not sir Bow down
Post #262873 3rd Jun 2014 12:59am
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Well this post has saved me from putting in a new post about the rubber on the back window. Laughing
Was getting some stuff out of the back when I noticed that the rubber is starting to perish and I thought I would replace it with some new rubber.
Hope its not too hard getting it off/on.
Will give the hot water a go anyway.
Thanks
littlecub
Post #262895 3rd Jun 2014 5:00am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I ended up having to cut through one end of mine and then peeled the rest off. It has left a line where previously painted up to the trim rather than removing it but at least I found where the rust bubble kept coming from as there was a rusty unpainted spot under the trim about 1 1/2" long, which I have treated with stabilizer but no the dealer can repair properly as agreed and remove the paint line they caused by bodging the original repair (twice) There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #262959 3rd Jun 2014 9:42am
paul271
Cheers Craig, its coming off to get rid of some tiny bubbles in the paint so its all good.
Post #262980 3rd Jun 2014 12:11pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Just as Craig said. Mine slid out no issues, but left a line in the paint that won't tcut out. Accept, some days your the pigeon, some days your the statue!
Post #263467 5th Jun 2014 7:26pm
paul271
Cheers guys. Am I right in thinking the newer models don't have this trim? Just the side ones?
Post #263502 5th Jun 2014 10:36pm
06-09 dont have any trims
10-13 have the side trims
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #263503 5th Jun 2014 10:38pm
