Home > Maintenance & Mods (L322) > Headlight wash and wipe
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
So my headlight wipers work. The washers don't at the moment but I am thinking/hoping it is just pump problem or blocked pipework.
Anyway, on the nearside headligh wiper, the cover which houses the washer jet is missing. Apparently I can't buy just this part, I have to but the whole arm Confused £66 Shocked Land Rover can Feck Off.
So my plan is this. When I sort out the water delivery to the jets, I am going to install washer jets on the bumper in front of the headights and do without the intergrated jets.
If there is a more complicated problem with the electronics that control the system. I will bypass it complete and install an after market system just for the headlight washers and have them controled from a rocker switch. I can do this for less than £30.
Land Rover can shove their overpriced/over engineered systems up their Censored
Post #264529 10th Jun 2014 9:23pm
Guessing you have xenons, the wipers and washers have to work for MOT.
There is a LH (so should be nearside, even if you are in Norfolk Wink )wiper unit on ebay for £24 probably more if you hunt around
http://www.ebay.co.uk/itm/13626-Range-Rove...417c5a326a
Thumbs Up .
Post #264542 10th Jun 2014 10:12pm
iphs
Yes I have and yes they have to wash and wipe. the wipe part is not a problem both work and there is nothing wrong with the blades. All I really need is the nearside cap piece that has the washer jet built in.
Those on ebay are just wiper arms without the bit I need.
Thanks anyway. Thumbs Up
Post #264549 10th Jun 2014 10:29pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
It was only reading this I realised the cap has the washer nozzle on it - mine has been missing on the passenger side for a few months and I didn't think anything of it - but strangely it passed its MOT a couple of days ago....... (with Xenons)
Whistle Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #264710 11th Jun 2014 5:32pm
iphs
I guess it depends on the tester at the time. With my luck I can be sure to get a real jobs-worth.
Whatever happens, I will make sure they work come test time, even if it looks like a pigs ear, so long as it delivers a blast of water to the headlight Job-Done.
However I refuse to line some Censored pockets (and I am not refering to the retailers). Lets face it, it's a 6"ish wiper arm with a water jet built in £66 Shocked
Or just to get it through the MOT fit in something like this:
http://www.ebay.co.uk/itm/Lamborghini-ACP-...51be2ed4c3
No brainer in my opinion.
Post #264724 11th Jun 2014 7:12pm
Discotigger
Just a thought, but give Cam Tech Craig (he's one of the site sponsors) a pm, he may have old wiper arms available from the facelifts he does. Might be able to do you a deal, he got me a replacement full headlight (xenon), sidelight, washer unit and wiper arm assembly for a good price...so may be able to help you.
Worth a try.
Post #264745 11th Jun 2014 8:49pm
iphs
Thanks Discotigger, I might just do that. Thumbs Up
Post #264758 11th Jun 2014 9:37pm
iphs
I have had no luck so far trying to get the small cap which has the jet built in, that is unless i am to pay silly money for a new or used arm with one fitted. I'm not known for surrendering many many gold coins for a bit of plastic that probably costs 20p to make.
So i am thinking of getting a couple of jets that fit onto the front bumper in the same way as later L322's. I can get all the bits I need to do this for less than £20.
Allthough the wipers are working. One of them does seem a little sluggish and jerky. So I am also thinking about removing the wipers and the motors and fitting blanking plugs over the holes. Again as far as I am aware later models don't have wipers, just jets (or am I wrong?). If I am not wrong, the only other problem I forsee might be that the electronics may detect that the wipers are disconnected and throw up an error message.
Has anyone done this or have any knowledge of potential problems please.
Post #268981 3rd Jul 2014 10:21pm
Why don't you simply unplug each of the wipers and see what happens, I pretty sure nothing will show anywhere.
The headlight wipers and washers are fed through a simple relay circuit with an input from the BCU which I presume is to make them operate in the manner they do.
Post #269023 4th Jul 2014 7:08am
