![]() | Home > Technical (L322) > TMC Aerial Position |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
the tmc gets its info from classic fm so 'its' antenna is the radio aerial which are built into the rear near and off side glass ... ... - .- -.
Turnover Member Since: 27 May 2014 Location: Norwich Posts: 39 ![]() ![]() ![]() |
Hi Stan,
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
The TMC antenna is actually in the rear windscreen. The amplifier is under the top interior trim panel on the passenger side of the wiper motor. What symptoms do you have with the TMC fault? Mine will not tune and stuck on 99.4mhz.
My problem is the lack of signal means the tmc is always disabled. tmc worked fine in the td6 I had before this one.
