Home > Maintenance & Mods (L322) > Coolant tank bleed procedure?
pld118
Hi,
The coolant expansion tank on the SC lost coolant last week via the tank bleed screw that had inadvertently been left insecure (I'm satisfied that there is no coolant leaking from any part of the system and that the bleed screw is working properly).
There is also enough coolant in the expansion tank, the coolant is sitting nicely within the tank range fill markers and the engine is not overheating.
However, once the car has been used, the coolant ends up distributed within the coolant tank, as pictured below, a concentration of coolant settling in the pictured top right chambers of the tank. Then, when left overnight, the coolant has not drained out of these chambers back down into the main tank (i.e settling again between the range fill markers). In fact, it only drains back down when I remove the coolant fill cap and then open the bleed screw.
Can someone please advise on the best step by step way forward for me to try?
Thanks.
Coolant settles like this even after sitting cold overnight:
Post #266816 23rd Jun 2014 8:21am
this is from the WM ryan [page 767] hope it helps,
i'll go a take a pic of mine in a minute. Wink ... - .- -.
Post #266818 23rd Jun 2014 8:35am
second pic looks the same as yours... ... - .- -.
Post #266819 23rd Jun 2014 8:44am
pld118
Thanks very much Stan.
It's just that last year when I had an issue with the bleed screw not being air/ water tight (solved with PTFE tape) once I'd topped up the coolant and bled the expansion tank, the coolant would, when the car was cold, settle back down between the range fill markers, which would seem normal and obviously allows you to check that the coolant is at a sufficient level; but if the coolant stays up in that pictured top right chamber, it becomes difficult to visually check if you've enough coolant, if that makes sense?
Post #266829 23rd Jun 2014 9:30am
makes sense Wink
its like theres an air gap between the two...mine has no problems and as said it does look like yours so i wouldnt worry..
btw, rotate your pic so we can get a better comparison. ... - .- -.
Post #266832 23rd Jun 2014 9:41am
ebajema
I remember mine did this as well. I guess that last year the bleed screw may still have leaked a tiny bit, causing the air to go in and letting the coolant settle. MY 2010 5.0 SC Galway green and sand interior!!
Post #267014 24th Jun 2014 1:09am
pld118
Well, almost one week after discovering the lost coolant and it hasn't lost a bit more. Definitely occurred because the bleed screw hadn't been closed properly during recent garage work. So, the PTFE tape around the bleed screw is a solution to any bleed screw missing an o-ring Thumbs Up
Coolant tank still showing as pictured above though with coolant, suspending itself in the upper chamber unless I open the filler cap and the the bleed screw when engine is cold which only then results in it draining back down and demonstrating the level is between the range fill markers. Although noted the comment that this is nothing to be unduly concerned about.
ps.. Don't know how to rotate picture from the iPad but every picture I post from my ipad on this forum now appears upside down!
Post #267284 25th Jun 2014 12:35pm
