![]() | Home > General > Wow and wow |
Regarding the tow bar , stupid question i suppose but the dealer and yourself have checked the cubby hole in the boot on the right hand side .... ====================================
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
If not in there, PF Jones, see here http://www.pfjones.co.uk are recommended by lots on here |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Welcome |
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 ![]() ![]() ![]() |
Welcome and you should of popped in for a Cupa |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I've got two farmer's hitches and could probably part with one ![]() |
Tonyrec Member Since: 02 Jun 2014 Location: Cumbria Posts: 46 ![]() ![]() |
Cheers.
Westfalia is the OEM for Land Rover tow-bars (i.e. they make them for Land Rover) so Westfalia items and Genuine Land Rover tow-bars are the same (except for a larger price tag on the Land Rover items usually ![]() The quick release / swan-neck is has two bits, one which goes into the 2" receiver on the Westfalia socket and provides another "connector" which the swan neck bit clips into. The farmer's hitch just goes straight into the socket with a pin and R-clip so is just as easy to remove (and, unless you remove the other bit of the swan neck, better ground clearance normally - always important for these people who never venture off-road in their Range Rovers!).[/quote] |
