![]() | Home > Maintenance & Mods (L322) > Coolant - how much and what type? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
this might help,
| steptoe Member Since: 23 Jul 2012 Location: london Posts: 382
Regardless of it being summer anti freeze also contains corrosion inhibators. Not a good idea to run the system with just water for any length of time. |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Suggest you drain it both from the rad and engine block, give a good flush then refill with 50/50. .
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Is it safe to top up with the same spec and type coolant albeit made by a different manufacturer?
I would seriously think about using another mechanic my friend... Thats not good practice at all... At best he should have booked you in to replace your coolant rather than leave you to potentially run around for months without... |
Parts Dept at RR main dealer said as long as the coolant is pink, organic and same spec it can be mixed with that of a different manufacturer to the one they use. Better safe than sorry! |
As the RR dealership was too far to justify going to for pink coolant, visited the local Jaguar dealership this afternoon and was assured this pink coolant is suitable for the 4.2 and can be safely added to top up the existing RR dealer supplied coolant.
Come on chaps.. Tumbleweed on this one.. do we think I'm safe to top up the existing coolant that's in the system with the Jaguar coolant? ... Or not
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
I would do it without worrying. so long as its pink I would mix with other pink stuff. |
You'll do for me Prop, thank you.
Main dealer has today confirmed that the below Jaguar pink antifreeze coolant is suitable for the L322 4.2 SC and is made of the same ingredients as the Oat 5 that they use.
Told you it was ok,,,, |
And I believed you Prop |
Phew thank god it was the right stuff. |
| All times are GMT |
