Home > Maintenance & Mods (L322) > S/C Gearbox slipping
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have an occaisional gearbox slip that seems to happen when either pulling away from rest or low speed. It always corrects itself once moving and does not seem to happen in Sports mode.
From a few searches on here, I have had the gearbox flushed and fluid changed last week and it has sadly not made a difference.
The odd thing is that I have noticed that the "D" on the dashboard disappears every time it happens, but the gearbox selector seems to be moving freely.
Any thoughts?? 4.2 Supercharged Vogue SE
Post #267707 27th Jun 2014 8:17pm
Have you had it plugged in and the fault codes read at all? Might be worth a shot to see if there's an electrical fault or something easily traced.
I would have done the same as you I reckon. Changing the fluid can't hurt in any case. Discovery 4 HSE
Post #267713 27th Jun 2014 8:48pm
MrSkill
I had what's sounds a very similar problem, was convinced it must be serious but found this and completely sorted;
http://www.fullfatrr.com/wiki/TDV8_Gearbox...s_of_drive
Put suspension up to highest setting, good spray of wd40 sorted it out!
Be interested to know how it goes - good luck!
Post #267719 27th Jun 2014 9:07pm
Chauch
Thanks guys, there were no gearbox fault codes found last week so sadly not easily traced, although I am liking the suggestion that some WD40 may solve it.
Assuming my serious lack of mechanical ability allows me to locate said linkage, then I will clearly be trying this tomorrow - keeping everything crossed Thumbs Up 4.2 Supercharged Vogue SE
Post #267725 27th Jun 2014 9:27pm
MrSkill
With suspension up to highest you can get underneath quite easily. I think it's on the drivers side but if you can get someone to move the gear changer whole you are underneath you can't miss it. Give it a good few squirts and go up and down the gears.
My symptoms were slipping out if gear when pulling away any at low speed. Was convinced it was going to be serious and was happily surprised in the end.
Hope it's same for you!
Post #267730 27th Jun 2014 10:23pm
Yep I had this a year ago , went nuts with some PTFE spray and all was good again Thumbs Up
A nice cheep fix just when you think your wallet is about to get a spanking Shocked 2008 MY Supercharged
Post #267744 28th Jun 2014 2:23am
allycraven
+1, usually does the trick.
while under there its worth greasing it up too, saves it happening again.. '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
'59 Ford Kuga Diesel (boring but AWD and 40mpg...)
2007 (07) Subaru Forester XTen 2.5 Turbo. (Roundabouts are fun again!)
2007 (07) 4.4 V8 Vogue (gone)
Post #267750 28th Jun 2014 8:26am
Chauch
Many thanks guys, all sorted and very obvious once you are under there and all for the price of a few squirts of WD40!
I cannot believe how different the selector feels, I had no idea it had tightened and it is pulling away so much more crisply again with no slippage whatsoever.
Thanks again guys Thumbs Up 4.2 Supercharged Vogue SE
Post #267754 28th Jun 2014 9:26am
