![]() | Home > Maintenance & Mods (L322) > Brake Squeal & Removal of pads without removing calipers |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
yes they can..
Thought so on looking at the caliper set up this morning but thought I'd check. Brilliant that diagram too, thank you very much Stan
you're very welcome mate.. |
Since also found a very helpful and straightforward you tube video of someone removing brake pads from a similar type Brembo brake caliper, purely for the purpose of re-greasing the brake pads and so he left the calipers on the Evo as he did this.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Should only need removing to replace the discs |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
The full fats have a pad wear sensor on each axle, front right and rear left if memory serves me right.
Whats the best way to remove the pins? |
Sledgehammer and poor unsuspecting soul to hold the pin |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
Compress the steel spring before you try to knock it out with a punch |
Compress it with what and why? |
Once you get the wheel off, you'll see that the pads held in place by sprung steel "springs", these are described in the above diagram as "anti rattle springs". Keep in mind these don't look like coiled springs.
Thanks Alan |
I see you were a boy scout! |
Probably going to try and do this later today.
