Home > Maintenance & Mods (L322) > inactive suspension
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
inactive suspension
Hit a pot hole the other week and inactive suspension message popped up but went of soon after but last couple of days it's came back and stayed on any ideas please
Post #268446 1st Jul 2014 9:30pm
Check Sensors all connected up properly and working, not bent levers or anything.
Put in off road height (if you can) and check for leaks
Do you have IIDTool/All Comms or similar to get fault code? .
Post #268450 1st Jul 2014 9:35pm
Dave ray
It's in normal ride height and it won't go to off road height what sensors ?
Post #268451 1st Jul 2014 9:38pm
Sorry, height sensors at each wheel. .
Post #268454 1st Jul 2014 9:40pm
Dave ray
Is it worth disconnecting the battery see if that does anything ?
Post #268464 1st Jul 2014 10:09pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Disconnecting battery wont do anything but make you work!
You need to read the fault codes .As you hit a pot hole is the tracking ok? you may find that's out??? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #268486 1st Jul 2014 11:39pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Hi, Had this on mine about a month a go, there are two small leads that run to the top of the suspension struts in engine bay that control the air suspension, they are very small wires and rub against metal and eventually bare metal causes a short and sends fault code, there is a dealer fix for it it, i had LR assist out and they soldered mine and then dealer did upgrade to new cables foc. it will keep happening until its done and drives like it has no suspension, mine kept happening until the fault remained.
Good luck hope you get it sorted.
Post #268487 1st Jul 2014 11:52pm
