![]() | Home > Maintenance & Mods (L322) > inactive suspension |
Check Sensors all connected up properly and working, not bent levers or anything.
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 ![]() ![]() ![]() |
It's in normal ride height and it won't go to off road height what sensors ? |
Sorry, height sensors at each wheel. .
Is it worth disconnecting the battery see if that does anything ? |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Disconnecting battery wont do anything but make you work!
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1515 ![]() ![]() ![]() |
Hi, Had this on mine about a month a go, there are two small leads that run to the top of the suspension struts in engine bay that control the air suspension, they are very small wires and rub against metal and eventually bare metal causes a short and sends fault code, there is a dealer fix for it it, i had LR assist out and they soldered mine and then dealer did upgrade to new cables foc. it will keep happening until its done and drives like it has no suspension, mine kept happening until the fault remained.
