Home > In Car Electronics (L322) > Rear entertainment screen blank
mk1paul
United Kingdom 2015 Range Rover Autobiography SDV8 Causeway Grey
Hi
Just picked up my first RR - a 4,2 SC from 2005
One of the rear screens is plain white - the passengers side headrest
The drivers headrest screen works fine.
Any ideas what this could be?
Post #268553 2nd Jul 2014 12:19pm
connections under seat or broken wires .. ... - .- -.
Post #268559 2nd Jul 2014 12:34pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
Re: Rear entertainment screen blank
Maybe a stupid comment rom my side, but are you both screens are set for the same input, i.e.. DVD, AV1...... Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #268564 2nd Jul 2014 12:45pm
mk1paul
Hi
Yes both showing DVD - I must admit I did check!!
As for the wires - any idea where exactly they are. Under the seats seems to be a real jungle of connections
Post #268571 2nd Jul 2014 1:04pm
mk1paul
Hi
Can anybody help with this please?
I have found the power lead under the seat - cleaned that out and reconnected but still the rear entertainment screen is white.
I am now stuck so would appreciate help.
Cheers
Post #269515 7th Jul 2014 3:48pm
RSE ECU is the big long one by the DVD player, check connections there... Then if you have found the main DVD seat plug, take the two torx screws out of the lower rear seat panel and remove it. Then follow the wire to the connector (behind that panel) remove it and swap that lead with the drivers side... Most probably that fibre optic lead that's fractured where your seat back bends...
Post #269551 7th Jul 2014 6:26pm
mk1paul
Thanks but I cannot get the rear panel off the seat. Have removed two t20 torx screws at bottom of seat but notjing is budging. Do I neef yo remove the leather pocket?
Post #269709 8th Jul 2014 6:04pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
There is no fibre optic "most" cable from the RSE module to the rear screens just the AV cable. Take a look at my RSE retrofit from over on the Disco 3 forum, it may help you in your diagnosis Thumbs Up
http://www.disco3.co.uk/gallery/albums/use...0Guide.pdf
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #270003 9th Jul 2014 10:08pm
mk1paul
Thanks for all the help here - it was indeed the cable that had frayed - now have pictures!
However, the headphones have lost stereo sound and when I look at the black plug that connects the DVD to the RSE, one of the pins is bent and loose.
Does anybody have a spare cable or fix suggestions?
It is the 13 pin to 13 pin alpine cable black in the mentioned guide
Thanks!
Post #271786 19th Jul 2014 2:35pm
