![]() | Home > In Car Electronics (L322) > Rear entertainment screen blank |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
connections under seat or broken wires .. ... - .- -.
ksskaret Member Since: 27 Oct 2013 Location: Tromsų Posts: 73 ![]() ![]() ![]() |
Maybe a stupid comment rom my side, but are you both screens are set for the same input, i.e.. DVD, AV1...... Range Rover TdV8 Autobiography MY2010
mk1paul Member Since: 01 Jul 2014 Location: Hampshire Posts: 102 ![]() ![]() ![]() |
Hi
Hi
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
RSE ECU is the big long one by the DVD player, check connections there... Then if you have found the main DVD seat plug, take the two torx screws out of the lower rear seat panel and remove it. Then follow the wire to the connector (behind that panel) remove it and swap that lead with the drivers side... Most probably that fibre optic lead that's fractured where your seat back bends... |
Thanks but I cannot get the rear panel off the seat. Have removed two t20 torx screws at bottom of seat but notjing is budging. Do I neef yo remove the leather pocket? |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
There is no fibre optic "most" cable from the RSE module to the rear screens just the AV cable. Take a look at my RSE retrofit from over on the Disco 3 forum, it may help you in your diagnosis |
Thanks for all the help here - it was indeed the cable that had frayed - now have pictures!
