Home > Maintenance & Mods (L322) > What diff oil
dhallworth
What diff oil
I'm looking to change the diff oil in our 2006 SC.
In the handbook it lists two different types of diff oil, one is for the locking rear diff which I don't have. According to the book, both of mine should have SAF X0 oil.
When Googled most results seem to suggest that it's the same as Castrol Syntrax Longlife. The weight commonly referred to is 75w 90.
Has anybody changed their diff oil? If so, what oil did you use? If I can't be sure of getting the right stuff I'll go to the dealer and buy it I think.
Thanks!
Post #269007 4th Jul 2014 12:05am
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I think all 4.2 SC have a locking rear diff standard, according to the sales brochure anyway
Post #269010 4th Jul 2014 12:13am
pld118
David,
Rear differential non-locking:
Texaco S5 75W90 API GL5 or Castrol Carbon 75W90;
Landrover TYK500010;
Comma SX 75W90 synthetic
The above is from the forum wiki entitled "Recommended Lubricants" (link below also shows spec for locking rear diff):
http://www.fullfatrr.com/wiki/Recommended_Lubricants
Post #269011 4th Jul 2014 12:20am
All UK spec supercharged had the locking rear diff I just think that pre terrain response models couldn't show the graphic on the 4X4 display so you aren't aware of when it locks/unlocks . 2008 MY Supercharged
Post #269013 4th Jul 2014 1:16am
dhallworth
That's makes sense as it was on the screen I was looking for the locking rear diff!
Thanks chaps!
Post #269027 4th Jul 2014 7:07am
when craig did mine he mentioned it was electronic [?] ... - .- -.
Post #269032 4th Jul 2014 7:35am
Send Dan a PM with your VIN & order it from him Dave... Its around £30 a diff for the correct JLR oil (so won't break the bank) & then you have piece of mind the oil is correct Thumbs Up
Might i suggest you do the transfer box whilst your at it?
Post #269033 4th Jul 2014 7:43am
dhallworth
Will PM Dan later on and get it sorted.
Craig, if you reckon it's worth doing the transfer box oil then I'll do that as well and will get it from Dan as well.
Cheers!
Post #269043 4th Jul 2014 8:50am
