![]() | Home > General > Let The Debate Begin.... |
need4speed Member Since: 14 Jul 2014 Location: Glasgow Posts: 4 ![]() |
Well first off im under no illusion. I know neither of them will be cheap to run.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7935 ![]() ![]() ![]() |
Always best to make a complicated car more complicated by adding an aftermarket LPG system I find. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Ive had both... Currently running a TDV8 and toying with a 5.0 change |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8043 ![]() ![]() ![]() |
No LPG allowed on the channel tunnel, so TDV8 for me |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
A further fly in the ointment - EGR & turbo failure on TDV8 cars ?
Initially I chose a TDV8 as replacement for the 4.2SC but then found out it had turbo issues (they were changing the turbo before the purchase but my concern was, what caused the turbo to fail in the first place). Then the perfect 5.0 SC came by and i was HOOKED.
I had a 3.6 TDV8 which was a very good car. I now have a 5.0 S/C which is an even better car. I prefer the smoothness of the petrol and I also much prefer the servicing costs; the diesels I've had always cost more come service time.
@need4speed
Check with your local main agents as three of our nearest won't let an LPG car into their workshops! |
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 ![]() ![]() |
The LPG argument is always an interesting one.
ibb1 Member Since: 27 Sep 2013 Location: London Posts: 80 ![]() ![]() |
My TD6 recently got written off and I've just bought a 4.4 LPG to replace it, not that I'd have been unhappy with another TD6 but this particular car was in very good condition, was the colour I wanted and had a meticulous service history including gearbox oil changes etc plus a top end LPG system installed, as there are a couple of Petrol stations with LPG available locally I decided to go for it. That said I was considering going for a TDV8 instead but it would have meant a more leggy one in not as good condition and there wern't any TD6s in the colour I wanted with the gearbox etc done at the time. 4.2 SC and later Jag engined 4.4s arn't meant to fare too well on LPG compared to the BMW engines are they?. |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
We have a 4.4 jag engined LPG conversion, and its fine |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3233 ![]() ![]() ![]() |
Moi aussi! |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Usually by those who've never owned an LPG vehicle. I have the same as you, a multi point prinz system, properly installed and registered, on a 2002 4.4 V8. Never any problem, and it's been fitted for 6 years and 75K miles. . Another benefit is the engine oil stays clear between oil changes.. ![]() |
