![]() | Home > In Car Electronics (L322) > 2005 touchscreen unit not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
fuse gone or maybe water ingress in the rear near side cubby hole .. ... ... - .- -.
If it has the MOST system already (my 05/05 built MY 2006 SC has the MOST) then it could be that. If one unit in the daisy chain is done (on mine the BT module) the entire system is out.
Could be water damage to the bluetooth unit , not uncommon, after that it gets more complicated and therefore expensive " not working " is a touch vague . But first look for evidence of water in the spare wheel well and on top of the phone unit ( it's the nokia branded box on top of the large stack of units in the near side rear compartment , this will be a start .
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Ok thanks, It's a 55' plate so touch screen sat nav etc.
Right, one of the fuses had blown so I replaced that and straight away the screen lit up with the LR logo screen but after 10 seconds or so, it just went blank.
Have just tried the cables facing each other on the nokia module but still isn't working.
I unplugged the tmc module and plugged it back in and the LR logo came on for a few seconds again.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Rich, when you unplug one of the fibre optic plugs, do you have a red light on one side? If no red light, no power |
Red light? On the power button?
Read it again Rich, do you have a red light inside the fibre optic lead? OK, open boot, unplug a fibre optic lead from one of the plugs (anyone it does not matter) do you see a red laser light? If so, you need to jump the plugs one at a time..... Simples |
Ah. Just had a look. No red light on any of them. |
Right, when I unplug and plug back in the TMC module, the logo comes up on the screen and I've just noticed that for that short time, there is a red light coming through the optic cable. As soon as the screen goes off, so does the red light. (It was flashing if that makes a difference) |
Also just wanted to mention, on my diagnostics from LR there are a couple of mentions about the battery;
Low battery voltage is always a problem with FFRRs and many other modern cars. So make sure you have a good battery and alternator and when playing with the engine off put a charger on to make sure the voltage stays well up. MY 2010 5.0 SC Galway green and sand interior!!
