Home > Technical (L322) > hdc,eas inactave and abs
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
hi guys just had replacement diff fitted ,both control arms and track rod end on the o/s front.
after 2-3 miles bong hdc,air suss inactive and abs lights lit orange.
hawrkeye shows 29 steering angle implausible on abs
and on air suss shows canbus fault sporadic fault present
any ideas guy at garage recons poss tracking ????
will reset but after 2-3 miles comes up again
help
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #272018 21st Jul 2014 11:37am
Is your steering wheel centered as it was before you had the work done?
Post #272019 21st Jul 2014 11:43am
trainmanone
it was slightly to the right ,must admit it is slightly more to the right now have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #272020 21st Jul 2014 11:50am
Could well be your problem.
I had similar when I changed a track rod end, if the steering whell is out of position it upsets the steering angle sensor and throws up faults. I simply corrected my steering wheel by adjusting the the track rod end I had fitted until the wheel was once again centred and all was well again. In view of the number of bits changed I think you may have to get the tracking checked.
Post #272021 21st Jul 2014 11:56am
trainmanone
thanks for that ,that's what the guy at garage said this morning . nee him to do ball joint then two tires tracking then hopefully all back to normal.
first time ive used this garage so thought might of been trying it on have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #272023 21st Jul 2014 12:00pm
Post #272025 21st Jul 2014 12:06pm
