![]() | Home > Technical (L322) > hdc,eas inactave and abs |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
hi guys just had replacement diff fitted ,both control arms and track rod end on the o/s front.
Is your steering wheel centered as it was before you had the work done? |
it was slightly to the right ,must admit it is slightly more to the right now have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
thanks for that ,that's what the guy at garage said this morning . nee him to do ball joint then two tires tracking then hopefully all back to normal.
