Home > Maintenance & Mods (L322) > Radiator after market or Landrover
Beanoraa
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hi guys just had my 4.2 2005 supercharged serviced and was told I need a new radiator,what best an after market one or a new one from Landrover
Post #272349 23rd Jul 2014 12:17pm
TugRR
Hello - recently had a replacement radiator on my AJV8 4.4 (perhaps it's a common fault with AJV8 engines ?).
Can't recall if my new one is Genuine, but my indie advised on either as the difference was probably only a sticker anyway !
The job killed several birds with one stone as the coolant was renewed and the A/C regassed -
Thumbs Up Where do you go after one of these . . . ?
Post #272367 23rd Jul 2014 3:16pm
mjdronfield
Mine needed one when I bought it and the garage sorted it. As a favour to them I picked it up from a company that makes radiators, so I know it wasn't a genuine part.
Never had an issue in nearly 3 years......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #272415 23rd Jul 2014 6:25pm
Beanoraa
Thanks for the feed back I think I'll try and source a good after market one
Post #272416 23rd Jul 2014 6:31pm
Sandyt
Npo experience of FF but p38s were notorious for eating them so I had one made by local company and changed plastic header and tank to brass also had them do a flow measure and make sure it was as efficient as poss from memory they were about 130 after market landrover 250 and hand made 200 so I would have one made and have all the weaknesses engineered out that way you will do itt once
Post #272428 23rd Jul 2014 7:28pm
Beanoraa
Sounds good but I don't know if anybody can do that over here in n Ireland , I'll have to do some more research thanks.
Post #272432 23rd Jul 2014 7:36pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
There a new LR one on e bay at the moment, starts at £35
Post #272438 23rd Jul 2014 7:52pm
Beanoraa
Just went with one from land rover, got a bit of discount as I new a member of staff £287 but only a years warranty. Had priced another one at £130 with a years warranty maybe should have gone with it.
Post #274085 3rd Aug 2014 7:56am
Dolphinboy
I just got one From AF advanced factors (sponsor on here) for £153+vat. It was a Nissens I think. Fitting cost £135 (3hrs) + vat.
I believe the gen LR ones are Behr.
Post #274118 3rd Aug 2014 2:00pm
I got one from AF, again a Nissens, similar price to above. Only difference to my original was that there was no drain valve, so to drain one has to drop the bottom hose and lose lots of coolant unless you are very clever. That said, had no problems with it and it was an easy fit. .
Post #274128 3rd Aug 2014 3:08pm
