![]() | Home > Maintenance & Mods (L322) > Radiator after market or Landrover |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201 ![]() ![]() |
Hello - recently had a replacement radiator on my AJV8 4.4 (perhaps it's a common fault with AJV8 engines ?).
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
Mine needed one when I bought it and the garage sorted it. As a favour to them I picked it up from a company that makes radiators, so I know it wasn't a genuine part.
Beanoraa Member Since: 27 Aug 2012 Location: N Ireland Posts: 18 ![]() ![]() ![]() |
Thanks for the feed back I think I'll try and source a good after market one |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Npo experience of FF but p38s were notorious for eating them so I had one made by local company and changed plastic header and tank to brass also had them do a flow measure and make sure it was as efficient as poss from memory they were about 130 after market landrover 250 and hand made 200 so I would have one made and have all the weaknesses engineered out that way you will do itt once |
Sounds good but I don't know if anybody can do that over here in n Ireland , I'll have to do some more research thanks. |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 ![]() ![]() ![]() |
There a new LR one on e bay at the moment, starts at £35 |
Just went with one from land rover, got a bit of discount as I new a member of staff £287 but only a years warranty. Had priced another one at £130 with a years warranty maybe should have gone with it. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
I just got one From AF advanced factors (sponsor on here) for £153+vat. It was a Nissens I think. Fitting cost £135 (3hrs) + vat.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
I got one from AF, again a Nissens, similar price to above. Only difference to my original was that there was no drain valve, so to drain one has to drop the bottom hose and lose lots of coolant unless you are very clever. That said, had no problems with it and it was an easy fit. .
