![]() | Home > Maintenance & Mods (L322) > Charging System Fault |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Anyone local to me (Lichfield - Burton on Trent area) with testing equipmet (MY 2010) - I have had the dreaded "charging system fault)" warning message come up on the dash.
Yea, did that the out put is only 11 volts.
Speaking to people I'm guessing I don't need the fault codes read as this is a simple alternator failure? Any thoughts? |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
If you are only getting 11 volts when engine is running, your alternator is cream crackered sir (unless it is a bad / loose connection).
Cheers |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 ![]() ![]() ![]() |
Charging System Fault......
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 365 ![]() ![]() |
Non of the above, your alternator will just need a new regulator. Never done a range rover but I wouldn't mind betting it could be swapped while on the car.
Thanks andygts 2011 TDV8 4.4 AB Bournville Brown |
Should the battery be recharged using a AGM specific battery charger or will the cars alternator recharge the battery back to a healthy condition.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Best to charge with a charger!! 2012 TDV8 Vogue SE 4.4 |
All sorted....
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Replaced alternator. An absolute swine to get out.....
