Home > Maintenance & Mods (L322) > Charging System Fault |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Anyone local to me (Lichfield - Burton on Trent area) with testing equipmet (MY 2010) - I have had the dreaded "charging system fault)" warning message come up on the dash.
24th Jul 2014 8:38am |
Yea, did that the out put is only 11 volts.
24th Jul 2014 6:39pm |
Speaking to people I'm guessing I don't need the fault codes read as this is a simple alternator failure? Any thoughts? |
24th Jul 2014 6:50pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
If you are only getting 11 volts when engine is running, your alternator is cream crackered sir (unless it is a bad / loose connection).
24th Jul 2014 7:30pm |
Cheers |
24th Jul 2014 9:12pm |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 46 |
Charging System Fault......
26th May 2018 1:02pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 339 |
Non of the above, your alternator will just need a new regulator. Never done a range rover but I wouldn't mind betting it could be swapped while on the car.
26th May 2018 5:16pm |
Thanks andygts 2010 TDV8 3.6 Galway Green |
26th May 2018 8:39pm |
Should the battery be recharged using a AGM specific battery charger or will the cars alternator recharge the battery back to a healthy condition.
1st Jun 2018 1:49pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Best to charge with a charger!! 2012 TDV8 Vogue SE 4.4 |
2nd Jun 2018 9:46pm |
All sorted....
6th Jun 2018 7:05pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
6th Jun 2018 9:29pm |
Replaced alternator. An absolute swine to get out.....
7th Jun 2018 9:18am |
